Displays MPLS EXP value to QoS profile mappings and whether MPLS EXP examination is enabled or disabled.
This command has no arguments or keywords.
N/A.
This command displays MPLS EXP value to QoS profile mappings and the status of MPLS EXP examination (enabled or disabled). These values are set using the configure mpls exp examination qosprofile command and can be resent using the unconfigure mpls exp examination command.
The following is an example of the output of the show mpls exp examination command:
# show mpls exp examination EXP --> QoS Profile mapping: 00 --> QP1 01 --> QP2 02 --> QP3 03 --> QP4 04 --> QP5 05 --> QP6 06 --> QP7 07 --> QP8 EXP Examination is disabled
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
